Question Emails Not Working For Mentions & Quotes
mindhunter77
It's my understanding that all users must have "Receive Email from Other Users " set to yes in order for them to get emails. If I am right, does anyone know a query I can use so that I can enable that in mass?
Right now, they are only receiving emails when I as admin mention or quote them.
I believe if you go to the Execute SQL Queries page in vB, there's a bunch of pre-defined operations in a drop-down. The relevant option should be there.
You'll need the appropriate config.php permission.
The setting "Allow Users to Email Other Members" must be enabled, then the "Display email" option will be available in that drop-down.
Yeah, that was enabled, but the query does not show up, do you have access to a vb3.8 you can copy the query from? I think he shows the actual query before it runs it.
It's off a vB4 forum but here's the query: UPDATE user SET options = options + 256 WHERE NOT (options & 256)
Remember to add the table prefix if you use it.
Hello @mindhunter77,
We hope your ticket regarding Advanced User Tagging has been addressed to your satisfaction. This ticket has now been closed.
Legacy Advanced User Tagging
