Bug DBSEO is changing the meta description for a radom comment
Website
https://www.worldhack.net/foro/
Product version
2.0.40
Forum version
vBulletin 4.2.x
Belazor
Staff member
Owner
Developer
It is not a bug. You can also use the Thread Tools to manually set the description if the auto-generated description does not fit your needs.
ikymbo
can you tell me where?
Why does this give me another description?
And it's not the only thead with this problem y have a lot of them i dont know exactly how many, but its really a big problem with SEO!
Belazor
Staff member
Owner
Developer
If you want the ability to customise the meta descriptions on a per-thread basis, you will need the Pro version of this mod and use the aforementioned Thread Tools page to edit them.
#12
[MENTIONS=Belazor][/MENTIONS] are you kidding me? your mod have problems, and the solution is buy the pro version? wtf?
do you now about SEO? do you now the big problem here? my foro is big !! i have over 200 threads or more with this problem, and the solution is buy the pro version and edit all my thread one by one! this is serious?
Belazor
Staff member
Owner
Developer
If you want total control over the exact content in the meta descriptions, then yes you will need the Pro version.
Alternatively, you can disable dynamically rewriting the meta tags via the DBSEO CP -> Dynamic Meta Tags.
Company Information
Staff member
Company Info
#14
Hello ikymbo,
DragonByte SEO
