Bug Copy option not working
EasyEasy
When using the copy option in the Raffles mod it produces a white screen in the ACP. Side panel is visible but the right handside is blank with just the vBulletin version details for the forum in it.
Could you please make sure display_errors is turned on in php.ini and that SKIP_ALL_ERRORS is not turned on in config.php?
I've discovered the source of the problem and it'll be resolved in the next version, thanks :)
Legacy DragonByte Raffles
