Question Cms disappeared - Please Help
I stay always in this way:
Are the crawlers of google that doesn't found the tags.
Database error in vBulletin 2.0.32:
Invalid SQL:
SELECT tagtext AS id FROM vb4_tag WHERE tagtext REGEXP "^(&[\#\da-z]*;|[^a-z\d])*(&[\#\da-z]*;|[^a-z\d])*[eÈÉÊËèéêë]v[iÌÍÎÏìíîï][cÇc](&[\#\da-z]*;|[^a-z\d])*vt[cÇc](&[\#\da-z]*;|[^a-z\d])*m[iÌÍÎÏìíîï][nÑñ][iÌÍÎÏìíîï](&[\#\da-z]*;|[^a-z\d])*[cÇc]([uÙÚÛÜùúûüµ]|u|Æ|æ)b[iÌÍÎÏìíîï][sŠš](&[\#\da-z]*;|[^a-z\d])*(&[\#\da-z]*;|[^a-z\d])*$" ORDER BY LENGTH(tagtext) LIMIT 1;
MySQL Error   : Got error 'invalid UTF-8 string at offset 45' from regexp
Error Number  : 1139
Request Date  : Tuesday, May 31st 2016 @ 10:28:25 AM
Error Date    : Tuesday, May 31st 2016 @ 10:28:25 AM
Script        : http://www.sigarettaelettronicaforum.com/tags/evic-vtc-mini-cubis.html
Referrer      :
IP Address    : 66.249.69.210
Username      : N/A
Classname     : DBSEO_Database_MySQLi
MySQL Version :
And also many pages aren't redirected to the correct url
Invalid SQL:
                    SELECT userid
                    FROM vb4_user
                    WHERE username REGEXP '^(&[\#\da-z]*;|[^a-z\d])*[cÇc][eÈÉÊËèéêë][nÑñ]tr[oÒÓÔÕÖØòóôõöø][sŠš]v[aÀÁÂÃÄÅàáâãäå]p[oÒÓÔÕÖØòóôõöø](&[\#\da-z]*;|[^a-z\d])*[iÌÍÎÏìíîï]t(&[\#\da-z]*;|[^a-z\d])*$'
                    LIMIT 1;
MySQL Error   : Got error 'invalid UTF-8 string at offset 24' from regexp
Error Number  : 1139
Request Date  : Tuesday, May 31st 2016 @ 10:50:25 AM
Error Date    : Tuesday, May 31st 2016 @ 10:50:25 AM
Script        : http://www.sigarettaelettronicaforum.com/members/centrosvapo-it/13-epipe-pipa-elettronica-legno-pregiato-centrosvapo.html/
Referrer      :
Username      : N/A
MySQL Version :
Invalid SQL:
                    SELECT userid
                    FROM vb4_user
                    WHERE username REGEXP '^(&[\#\da-z]*;|[^a-z\d])*bl[oÒÓÔÕÖØòóôõöø]g.html(&[\#\da-z]*;|[^a-z\d])*$'
                    LIMIT 1;
MySQL Error   : Got error 'invalid UTF-8 string at offset 26' from regexp
Error Number  : 1139
Request Date  : Tuesday, May 31st 2016 @ 10:42:03 AM
Error Date    : Tuesday, May 31st 2016 @ 10:42:03 AM
Script        : http://www.sigarettaelettronicaforum.com/members/naquix/blog.html/
Referrer      :
IP Address    : 157.55.39.159
Username      : N/A
MySQL Version :
I don't know if the utf8 is setted good in the Dbseo (and here it seems yes) and in the Vb (because here we try to make some changes to fix the problem but nothing change) so if you that are expert about these things can give check also to this sure is good.
Another example:
Invalid SQL:
SELECT tagtext AS id FROM vb4_tag WHERE tagtext REGEXP "^(&[\#\da-z]*;|[^a-z\d])*(&[\#\da-z]*;|[^a-z\d])*[cÇc][aÀÁÂÃÄÅàáâãäå]p[aÀÁÂÃÄÅàáâãäå][cÇc][iÌÍÎÏìíîï]t%C3%A0(&[\#\da-z]*;|[^a-z\d])*(&[\#\da-z]*;|[^a-z\d])*$" ORDER BY LENGTH(tagtext) LIMIT 1;
Error Number  : 1139
Request Date  : Tuesday, May 31st 2016 @ 01:39:49 PM
Error Date    : Tuesday, May 31st 2016 @ 01:39:49 PM
Script        : http://www.sigarettaelettronicaforum.com/tags/capacit%C3%A0.html
Referrer      :
Username      : N/A
MySQL Version :
The word is "capacità" (capacity) more used...
I'm trying to look into this but the AdminCP account I had seems to have evaporated. Could you please restore these details?
Fillip H., Hi Fillip, now all the panel is enabled, you had also the ftp details.
Any way now it's all ok.
I am still receiving login errors when I attempt to login with the previously saved details. Can you please PM me with the updated AdminCP details?
As you can see also the links redirections aren't working:
Invalid SQL:
SELECT userid
FROM vb4_user
WHERE username REGEXP '^(&[\#\da-z]*;|[^a-z\d])*[sŠš]v[aÀÁÂÃÄÅàáâãäå]p[aÀÁÂÃÄÅàáâãäå]t[oÒÓÔÕÖØòóôõöø]r[eÈÉÊËèéêë](&[\#\da-z]*;|[^a-z\d])*[cÇc][oÒÓÔÕÖØòóôõöø]m(&[\#\da-z]*;|[^a-z\d])*$'
LIMIT 1;
Error Number : 1139
Request Date : Tuesday, June 7th 2016 @ 07:43:28 PM
Error Date : Tuesday, June 7th 2016 @ 07:43:28 PM
Script : Sigaretta Elettronica Forum - Svapatore.com - Prodotti
Referrer :
IP Address : 40.77.167.86
Username : N/A
MySQL Version :
Wow all redirections are finally working :)
I can't believe it! Great Fillip! :)
So I hope these emails errors will stop now.
I really hope...
Also one thing...
I see in your forum that my links are shown those wrote friendly
in my one not, is there the xml link that is cut...
Can you please tell me where to change this option?
Yes but how I must set the Link Titles option?
(I have tried in any way but the link are always the same in the posts.)
And the External Link option must stay on "yes" true?
Wow FIllip still now no others errors arrive. :) You make me wait one month :D but you fix me the problem. 1 million time Thanks! :)
I was going crazy.... and this only you could repair it.
Really many Thanks. :)
Now it remain only the internal link option...
Oh is it internal links that's the problem? The setting above the one I pointed to in my previous post controls that :)
Yes exactly, but I don't understand how to set it.
What I need to know is wrote in my previous posts. :)
