Bug Change Php 5.4 to 5.6 and not works
pepecillo
I have a problem with DragonByte Tech: Advanced User Tagging (Lite). I change my forum to another Server. The old server have php 5.4 and the new server have php 5.6. In the new server Advanced User Tagging not works. I can tag users but when I go to mywebsite.com/usertag.php?do=profilenotif&tab=mentions to see the mentions, it have a blank page with the message "Not supported".
Can you help me?
Hi there,
Unfortunately I don't believe our mod is the cause of this issue, as there is no such message in any of our code, sorry :(
Hi there,
I have not changed anything else, neither version of vbulletin nor nothing at all. Only the php version. Can any plugin function not be compatible with that version of php? If I buy the payment version will it work?
As I said, the issue isn't in our mod, so buying it will not solve your problem. Can you please disable all other modifications, leaving only our mod enabled, and try it again?
Hello pepecillo,
Legacy Advanced User Tagging
