Question Banners for Guests only
Mick
Hi,
I am running the latest version but having a few issues configuring the usergroup permissions for ads.
I created a new AD format in the vbulletin section called DW Store.
I then added permission that if the user was a guest the add would display.
*Now I add a banner in the forums ads menu, but there is no option to choose DW Store for the template location?
Where am I going wrong.
Banners are showing to everyone when I select above the footer
Cheers
Mick
This mod cannot use custom ad configurations you've added in the vBulletin Ads manager, unfortunately. You would need to edit one of the "DragonByte Forum Ads" ad configurations, which would make ALL banner spaces on that location visible to guests only. If you are okay with this, then editing it will give you the same control as the new ad configuration you added, and all of them will be supported :)
Legacy DragonByte Forum Ads
