Bug Articles won't load
sleeperzzz
Hi DBTech,
No idea why but when Ajax Threads is enabled our articles won't load.
We can go to the articles page to view all articles created but once you click on one to open it up you get a long loading time and a blank page as result. With only the background shown.
There is no header, footer or any content showing.
Once i disable Ajax Thread then all works as normal.
I noticed a topic a few version ago with same issues but with Blogs.
So no idea if this is the same issue or a new one just wanted to let you guys know
Can you try turning on debug mode in both the root and the /core/ config file and see if there's any error messages?
Yes i did in fact try this method as i assumed at first there was something wrong.
But still received a blank page with no errors showing.
If i need to test anything else then let me know.
For now i disabled Ajax Thread but i'm all in for getting it up and running again :)
Sorry for the delay.
So yeah i verified it and Display_erros was on in the php.
anyways turned Debug on and enabled the plugin again here are some screenshots
So i an click articles and see the created articles
And once i click on the articles to read the entire post.
Then all i get is a blank page.
If i open up the console i get some loaded HTML
So yeah no idea what is up with that.
Anyways if i an aid again just let me know always glad to help out
Btw with almost no plugins to block it i decided to add a screencap of what products i do have on.
Yo,
Will create the accounts this week and send them to you.
Been a little busy past few weeks hence the late reply :)
cheers
Hello sleeperzzz,
This ticket has now been closed with the status No Response.
Legacy AJAX Threads
