I'm not sure what the best solution for this is....and I know you aren't designing the chat to work with mobile devices. I personally use an iphone and the chat works great on it. However, the one issue is being able to double click a chat to edit or delete it. On iOS the double tap causes the page to zoom out rather than have a double click effect. I'm thinking if you add to the member name drop down an option to edit and/or delete that would give a potential solution to this shortfall with iOS.
BTW- I have customized my drop down menu. Screen shot attached. I think this layout makes the most sense as it puts the chat @ someone right on top and the private chat option right below it. It also has the X to close the menu right at the top where people are expecting to see it. I also created a custom phrase for private chat to separate it from the phrase private message because it was confusing since that was already used for forum private messages (which I also created a new menu item for that as well). Just pointing all this out...cause if you like it feel free to rearrange vbshout. (Saves me customizing during each upgrade. :) )
Shame you don't run vB4, as those customisations would be automatically merged into the template :P
We'll add a "Delete Shout" entry in that menu in a future version :)
I started working on vb4. Hopefully someday I'll be there. :)
---------- Post added at 10:33 ---------- Previous post was at 10:14 ----------
EDIT option would be handier than delete especially with your new handling of edited shouts once the shout is in edit mode, you have a nice delete option available. So you would kill two birds with one stone by having EDIT.
BTW- this feature can't come soon enough for me. I'm planning to use the chat box here in a week to run a raffle at a show. Being able to do all the chat updates from my phone would be a huge help for that.
thanks
There will be both an edit and a direct delete link in v6.2.0, which is currently scheduled to release tonight :)
