rtbs
I just uploaded to latest version.. I was on 5.3 something
After the upgrade, the chat box does not show on my forum home.
I had the manual insertion into my template in all my skins and it was working fine. Now it does not show anymore.
{vb:raw vbshout}
These are the new instructions:
To put vBShout in a custom location, do the following:
Step 1: AdminCP -> DBTech - vBShout-> Instance Management -> [Edit].
Step 2: Change the Auto-Display Shoutbox setting to Disabled.
Step 3: Write down the the Varname setting. For the default shoutbox, it's instance1. The rest of this guide will assume you replace instance1 with the actual Varname if it is different.
Step 4: Enter the Style Manager and add either {vb:raw show.vbshout_instance1} (vB4) or {$show[vbshout_instance1]} (vB3) to the templates you wish the shoutbox to appear in.
Follow these steps as described and you will have total control over the position of the Shoutbox.
Please note that some locations may not work as intended on vBulletin 3.8, and also note that it is not designed to go in the Forum Blocks side-bar (vBulletin 4).
Hope that helps :)
