Duplicate of https://www.dragonbyte-tech.com/f52/has-anything-changed-21262Hello,
After updating to the latest Advanced Post Thanks / Like v3.6.3 we have some bugs:
1. Clicking on Like/ thanks ..etc buttons not giving any result
2. The version displayed inside VB is 3.6.2
Have you created a button with the varname "absent"?Another error found trying to rebuild statistics:
Database error in vBulletin 4.2.3:
Invalid SQL:
UPDATE vb_dbtech_thanks_statistics SET
### UPDATE QUERY GENERATED BY fetch_query_sql() ###
`likes_received` = '665',
`thanks_received` = '238',
`likes_given` = '262',
`dislikes_given` = '87',
`thanks_given` = '140',
`dislikes_received` = '7',
`absent_given` = '1'
WHERE userid = 2146;
MySQL Error : Unknown column 'absent_given' in 'field list'
Error Number : 1054
Request Date : Friday, February 17th 2017 @ 11:42:59 AM
Error Date : Friday, February 17th 2017 @ 11:43:00 AM
Script : Autentificare - Comunitatea pasionailor de tenis de mas - vBulletin Panou Administrare
Referrer : Autentificare - Comunitatea pasionailor de tenis de mas - vBulletin Panou Administrare
IP Address : 89.121.218.236
Username : clau
Classname : vB_Database
MySQL Version : 5.1.73-cll
Did you rename it manually or did you delete the existing button and remade it?Yes, I created a varname "absent", but this was some time ago, and it was already changed to other names at the date of this update:
https://s27.postimg.org/5c7uoaj6p/thanks.jpg
If you renamed the button varname manually in the database, that would be the cause of this problem and your best bet would be to reinstall the modification.
Please do not attempt to manually rename varnames in the database.
I didn't made any modification (varname) in the database.Update: whatever you did in the database to rename the button varname..
There is no option to rename the varname in the Edit Button interface. Once a button has been created, the varname cannot be modified.I didn't made any modification (varname) in the database.
I renamed the varname in the interface :"edit button"
Unfortunately your site seems to have either crashed or the server has banned my IP address as I can't access your site to assist you further![]()
