Robbed
I installed the gallery today.
A few issues i've noticed.
1) When uploading a file and choose downloadable it doesn't save, I have to edit the image again and check off downloadable and it works.
2) Some weird permission issues on ftp. When I create a new instance it assigns user: apache and my upload folder has 777 but when creating new instances it sets the permsions on the folder to apache 2755 so i can't make changes using ftp or use mass import.
3)By default gallery home module in admin cp isnt selected, if you browse to that instance you receive file missing.
4)When creating an instance and assigning instance permssions it doesn't save unless I go back in and set them again.
5)Footer still shows version 1.2.2
I believe I have it all fixed for the next version. I have a few more things to work on before I release it, let me know if you come across anything else. Thanks for letting me know :)
Thanks
I noticed when using the VB style option the footer gets messed up and the skin chooser appears on the right side, it works fine on new style.
This is when viewing an image only
Is it a home grown style? I can't replicate it here or on my local dev. If you want to give me an account I'll check it out. Doesn't need to be an admin for now, just an account that can see the gallery.
I tried it on VB default style, it could be another pluggin causing the issue.
It only happens on image display page when setting to vb style in admincp, new style works fine when displaying images.
I will send you account info sometime this week
Legacy DragonByte Gallery
