Legacy Will vBOptimise add features like vB4 SuperCharged has?
This may or may not be something we'll be doing with this mod. The problem with compressing JS and CSS is that it often breaks a lot of modifications. We often have to tell users to disable SuperCharged as it causes some of our modifications to break. If this is something we can do without breaking modifications then, sure, we could considered it. Cosmic should have a better answer for you however :)
It's not a route we will be taking with vBOptimise since, as david mentioned, it regularly breaks quite a few different things/modifications.
Cosmic
