Question vbulletin 4.2.5 DragonByte SEO Lite problem
KLAMP
DragonByte SEO Lite vBulletin 4.2.5 version does not work , disabled plugin plugin when the plugin is active vBulletin 4.2.3 version does not work vBulletin 4.2.5 version does not work please help
This mod works perfectly on vBulletin 4.2.5 as you can see on this forum. Can you please be more specific?
Thank you so much for writing the answer .htaccess content as I wrote below vbulletin 4.2.5 version of the pages do not open as HTML extension dbseo General Settings and forum Settings section of the settings do not work what I did
<IfModule mod_rewrite.c>
	RewriteEngine On
	# RewriteBase /
	# Options -MultiViews
</IfModule>
Those .htaccess rules are out of date, please see the readme.txt file from the latest version of the mod for the updated rules.
In the readme.txt, .htacess did not change anything as I wrote below. I would like to ask you to write the code for 4.2.5
 	RewriteEngine On
	RewriteCond %{QUERY_STRING} !dbseourl=
	RewriteRule ^(.*\.php)$ dbseo.php?dbseourl=$1 [L,QSA]
That is the correct rule set for the latest version of Apache, we are running it on this site without problems :)
In that case you will need to contact your system administrator for further assistance, if any changes to the .htaccess file is needed they should be able to advise you further :)
The problem is that you are using rules for an apache server. You need rewrite rules for litespeed instead.
Contact your host and have them convert it.
Hello KLAMP,
