Question url problem
below in my htaccess. not sure if correct.
RewriteEngine On
RewriteCond %{HTTPS} !=on
RewriteRule .* https://yoursite.com%{REQUEST_URI} [R,L]
# RewriteBase /forum/
RewriteCond %{REQUEST_FILENAME} -s [OR]
RewriteCond %{REQUEST_FILENAME} -l [OR]
RewriteCond %{REQUEST_FILENAME} -d
RewriteRule ^.*$ - [NC,L]
RewriteRule ^threads/.* showthread.php [QSA]
RewriteRule ^forums/.* forumdisplay.php [QSA]
RewriteRule ^members/.* member.php [QSA]
RewriteRule ^blogs/.* blog.php [QSA]
ReWriteRule ^entries/.* entry.php [QSA]
RewriteRule ^(?:(.*?)(?:/|$))(.*|$)$ $1.php?r=$2 [QSA]
# Options -MultiViews
Can you try changing your .htaccess file to this:
<IfModule mod_rewrite.c>
	RewriteEngine On
	# Force SSL:
	RewriteCond %{HTTPS} off
	RewriteRule (.*) https://%{HTTP_HOST}%{REQUEST_URI} [R=301,L]
	# Force www:
	RewriteCond %{HTTP_HOST} !^$
	RewriteCond %{HTTP_HOST} !^www\. [NC]
	RewriteCond %{HTTPS}s ^on(s)|
	RewriteRule ^ http%1://www.%{HTTP_HOST}%{REQUEST_URI} [R=301,L]
	RewriteCond %{QUERY_STRING} !dbseourl=
	RewriteRule ^(.*\.php)$ dbseo.php?dbseourl=$1 [L,QSA]
</IfModule>
Hello Hengz,
