Bug There is no way to delete a field
What type of fields? Custom profile fields are deletable in the vB custom profile field manager. Fields such as username, password, etc. can be hidden if you set the display order to 0. Although it should be noted that hiding certain of these fields may make registration impossible as vB requires basic stuff like a username / password.
Hmm, so would it be possible to tie into a little more information on your registration page? Not necessarily duplicate the work, but a couple things like an Add button that maybe opened the Add New Profile Field page in vB? Same with deletes, etc? No idea if you can hook in there or not at all, but... just to make it so you don't have to exit your registration page settings in order to do some of the things needed.
I've added a couple of new links in the manage fields page which should hopefully make things a bit more streamlined. :)
Legacy Advanced Registration
