Bug Thanks Button click not working
ocin
Hi,
yesterday we've installed for testing the Advanced Post Thanks Button Plugin.
Unfortunatly it is not working when you try to click any button.
The hover link just says "javascript://".
I went to the templates and had a look directly into "dbtech_thanks_postbit_entries_actionbit" and I guess there is the target missing in the "a href":
<span class="dbtech-thanks-button-control"<vb:if condition="!$show['_cannotseeclicks']"> data-button="{vb:var button.varname}" data-postid="{vb:var post.postid}"</vb:if>>
<a href="javascript://" <vb:if condition="$button['canclick']">name="dbtech_thanks_button" data-postid="{vb:var post.postid}" data-button="{vb:raw button.varname}"
Is that true or didn't I installed the plugin correctly?
Regards
Nico
Hmmm, I just see here it is the same.
Okay, than the target looks correct but why is it not working. Also here it is not working.
Nico
Nico
Okay nevermind!
Sorry for double post!!!
It is working now.
The issue was the permission on the files. I just saw it wasn't correctly set.
Please close the ticket since it isn't a bug nor a problem anymore.
Nico
