Bug some very small errors
tomtransg
hello, I just installed the add-on DragonByte eCommerce, and there are some very small errors, please help me, or guide me where to fix it.
  • Cart icon has not shown.
  • I can change the size of the buttons to better match the theme of my website.
These are issues with your skin and will need to be addressed by your skin developer. Unfortunately it is not possible for me to guarantee compatibility with every skin.
If your skin developer needs me to make any changes to the core product to support their skin, then they can feel free to let me know the changes required.
8782
Hello, and then solved the icon problem. however, the size of the cart icon is larger than other icons. Can you help me with an extra.less css code to adjust the small icon size?
I wouldn't know how to do that, your skin developer should be able to advise you. The icon in the default skin is the same size as all the other icons, so if your skin uses a non-standard icon size I would not know what size your skin uses.
Hello @tomtransg,
4.86 star(s) 7 ratings
