Bug Shop and Credits bug
Faust
One more thing I have here,
Is with the shop and credits shop icon on top of the page next to avatar profile
Any advice how to fix this, or I should contact TH ?
Thanks
I'm gonna keep the credentials from the previous report so I can look into this. I'll let you know if I'm able to resolve this or if I need you to contact TH.
I have been able to work around this on my end. While UI.X themes do not support the full range of icons like FontAwesome, they will at least not show up broken as of the next versions of Credits and Shop.
I saw you where able to do it , but seems the issue is here, just enabled the shop, and seems to be same issue
Keywords being next version. I reverted the test edits I made on your site, because customising the templates may prevent you from receiving future fixes to those templates.
Please just wait for the next version to switch the navbar over to displaying on the right side.
The updates will be released once a sufficient amount of time has passed since the last bug report.
Hello @Faust,
Hello @Faust,
DragonByte Shop
5.00 star(s) 3 ratings
