optix
Hi!
Is there a readme file? Basically, I'd like to have something that could outline the relationship between:
Achievements
Categories
Criteria
Rewards
If there's only a readme for the Pro version please could I see that? I'll be getting that one once I've got the Lite figured out.
Many thanks,
Wes
A manual is in the works :)
However, the brief summary is:
* A Category is used in Achievements and Rewards to group them.
* A Criteria is used to determine how to earn an Achievement.
* A Reward is manually handed out to people who deserve it.
Thanks!
Each achievement is based on a single criterion?
Also, I see there's two type selections: value & points. So, using "Shouts" as a criterion, then I should choose Value rather than points?
You can use multiple criteria in an Achievement.
Points = for instance Points for Shouts.
So say you set up a criteria where points for shouts >= 5, and you have 0.5 point per shout, thats 10 shouts to get the Achievement.
Value = actual amount
So say you set up a criteria where shouts >= 5, thats 5 shouts to get the Achievement.
Legacy vBActivity & Awards
