Bug Problem installing VB Optimise in multidomain
WEF
Hi, I tried to install vb optimize on several subdomains
br.worldescortforum.com
ar.worldescortforum.com
pe.worldescortforum.com
cl.worldescortforum.com
uk.worldescortforum.com
in.worldescortforum.com
But I have had serious problems and finally I had to uninstall the plugin.
After installing and configuring the plugin using memcache, I had all the cached pages of all my subdomains.
For example, on ar.worldescortforum.com I saw br.worldescortforum.com or on pe.worldescortforum.com i saw uk.worldescortfoum.com...
This is a very serious mistake
How can I avoid caching between subdomains ???
I want the plugin to work on each subdomain independently.
Not.
I am talking about, when I setup memcache in my config.php file like this:
$ Config ['Datastore'] ['class'] = 'vB_Datastore_Memcached';
$ I = 0;
// First Server
$ I ++;
$ Config ['Misc'] ['memcacheserver'] [$ i] = '127.0.0.1';
$ Config ['Misc'] ['memcacheport'] [$ i] = 11211;
$ Config ['Misc'] ['memcachepersistent'] [$ i] = true;
$ Config ['Misc'] ['memcacheweight'] [$ i] = 1;
$ Config ['Misc'] ['memcachetimeout'] [$ i] = 1;
$ Config ['Misc'] ['memcacheretry_interval'] [$ i] = 15;
I see, content from another forum.
For example in the subdomain br.worldescortforum.com I see the content of uk.worldescortforum.com
This is a serious mistake, how can I avoid it? Thank you.
This is my configuration in the plugin
Sorry, could you please explain in more detail the nature of your setup and what you mean when you say "content of X"?
Are these subdomains entirely separate forums, or are they translations of your one forum?
Hello AD2WEB,
