Bug No Rewrite vbDownloads after Reinstall
webi
Hi Fillip,
after an uninstall and reinstallation unfortunately the rewrite for the vbDownloads no longer works.
Rewrite is enabled for vbDownloads but it remains vbdownloads.php instead of downloads.html.
Best Regards
Can you please make sure you're running the latest version of vBDownloads, just to be safe?
It may be an incompatibility with a newer version of DBSEO, I'll take a look and get back to you as soon as I can :)
Sorry for the delay :(
I've added a hotfix to the latest version of vBDownloads which should resolve this issue.
Have vbDownloads re-downloaded and re-installed. Unfortunately, the problem continues. "Page not found" is displayed.
Hello webi,
