Bug My Sql error
Website
https://twistedcastle.org
Product version
1.2.1
Forum version
vBulletin 4.2.x
#1
Hi, I tried to disable this product to try fix the double footer issue, and when I did, I started to get ths database error. I currently cannot acces my main site, but still have access to the ACP. I tried re enabling the product, doing an uninstall and reinstall, and still getting the error.
WHERE 1=1;
MySQL Error   : You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near ')
			) AS entry
			LEFT JOIN user AS user USING(userid)
			LEFT JOIN avatar A' at line 6
Error Number  : 1064
Request Date  : Monday, November 21st 2016 @ 06:38:51 PM
Error Date    : Monday, November 21st 2016 @ 06:38:51 PM
Script        : http://twistedcastle.org/forum.php
Referrer      :
IP Address    : 50.168.28.235
Username      : TwistedDaddyDom
Classname     : vB_Database_MySQLi
MySQL Version : 10.0.28-MariaDB
#2
I fixed the issue by disabling the advanced post Thanks Mod from yourself. This fixed the DB error. I then reinstalled the Live stream mode which is again functioning, but still showing the double footer.
Belazor
Staff member
Owner
Developer
You'll need to delete the extra footer text from the "Copyright Footer" setting in the vBulletin Options in order to fully resolve the double footer issue.
Company Information
Staff member
Company Info
#4
Hello Ashlar217,
Forum Live Feed & User Wall
