Bug loading problem on updated versions
jellybelly
Hello please can you help i have to use vbshout 6.07 if i use an more updated version the shout takes too long to load i have not updated to the latest vesion of vb i am using vb 4.20 patch level 2 is this the reason
thanks
Unfortunately that's not something we're able to do anything with, there's been no changes in the way shouts are loaded from 6.0.7 to 6.1.0 :S
something is not right i have updated to the latest version my shouts are not loading as i explained previously above i did see that a few members have also complained that on the the new version on a different support thread they had problems the same as i have just mentioned
If you're having a problem then please explain it in as much detail as possible and/or include screenshots where applicable, I can't assist you based on something not being right ;)
