Legacy Incorporating Side Blocks
delicateglow
To incorporate side blocks for each category tab.
It'll work just the same with forum sections like how it is now, but for side blocks!
And possibly, if you wanna extend that, have it so you can favorite side blocks as well
Just to check what you are suggesting:
The ability to have a sideblock which can contain the tabs system and list the forums you want for a particular tab or category?
No, I mean like this:
Say you're at Category 1
It'll have Sideblocks A, B, and C.
Go to Category 2
It'll have Sideblocks D, E, and F
But just like how the current system works, you can add sideblocks to your favorites.
Right, so you mean organize the sideblocks in to a tabs system. Interesting idea. I'll get some feedback from Cosmic on this to see what he thinks about it as well
Thanks for the cool suggestion. :)
5K
8K
3K
Legacy DragonByte Forum Tabs
