How to Order Pro Versions?
First of all kudos on all the cool plugins! Tried a number of demos and very excited to buy fully-functional versions!
Here are my pre-sales questions:
1)How do I order the "pro" versions? For example for the vBActivity & Awards plugin, in the "Features List" I would see "Professional Only Benefits", but there's no mention of the pro version in the ordering options:
2)I'm wanting to order the following plugins - can I get a discount please? :)
vBActivity & Awards - lifetime
Advanced User Tagging - lifetime
vBSuper PM's - lifetime
vBAvatars - lifetime
vBSignatures - lifetime + signature style: business addon
DragonByte Raffles - lifetime
3)We have a dev forum that we run testing on, that I'd like to install the plugins on first to play around with and decide on settings, before deploying to the real forum. Would that be allowed by your licensing terms?
Thank you very much in advance for your response!
Sincerely,
Amy
Belazor
Staff member
Owner
Developer
The screenshot you are showing is the Pro version :)
The Lite version is what you get when you click the Download Demo button.
You will receive an automatic bulk purchase discount for your order, more information can be found here: https://www.dragonbyte-tech.com/info/discounts/
No problem whatsoever :)
You will not run into any issues running them on a test board even if the URL specified in the client area is for your live site.
#4
I have additional questions if you wouldn't mind :)
1)Does VBAvatar work with the points system in the VBActivity & Awards plugin?
2)What's the main difference between VBActivity & Awards, and VBCredits II Deluxe?
3)Would it be possible to get the plugin with branding first, and then purchase the branding-free separately later if we wish to remove the branding?
Thanks again for your help!
Amy
Belazor
Staff member
Owner
Developer
It will, you'll need to manually link them but you'd need to do that with any points mod.
vBActivity is not intended to be used as a points mod, if you need a points mod you'll want vBCredits. vBActivity is meant to enable you to create Achievements for things that happen around your forum, e.g. members hitting 500 posts, etc. Additionally, you can manually award people with medals/awards for things like special events.
Absolutely, to remove the branding after purchase you would simply re-download the mod and re-upload it / re-import the XML file :)
Company Information
Staff member
Company Info
#7
Hello vortexstm,
