Question How do I
ringnews24
I bought the pro version.
My shoutbox used to be at the top of everypage. How its not how do I fix that?
Active users at right side only says my name even though there are other users in the shoutbox.
Custom commands are working but soon as I say type - /finalwarning username it doesn't work
(Pro) Minimum Posts Per Day The minimum amount of posts per day (as seen in the member profile) before someone of any usergroup can access the Shoutbox.
When I change this to 3 no one can post on the shoutbox apart from admin even if they has posted 3+ times.
How do I make the 3 post count rule work for all admin as well?
To put vBShout in a custom location, do the following:
Step 1: AdminCP -> DBTech - vBShout-> Instance Management -> [Edit].
Step 2: Change the Auto-Display Shoutbox setting to Disabled.
Step 3: Write down the the Varname setting. For the default shoutbox, it's instance1. The rest of this guide will assume you replace instance1 with the actual Varname if it is different.
Step 4: Enter the Style Manager and add either {vb:raw show.vbshout_instance1} (vB4) or {$show[vbshout_instance1]} (vB3) to the templates you wish the shoutbox to appear in.
Follow these steps as described and you will have total control over the position of the Shoutbox.
To put the shoutbox on every page, edit the navbar template.
The other users may have flagged themselves as Invisible.
Can you please provide more information than "Doesn't work"? Do you receive an error message? Is the output different than what you expected and if so, what is the output and what did you expect it to be? Can you screenshot the configuration?
You want the "(Pro) Minimum Posts" setting. As per the description, the setting you're trying to change is posts per day, not total posts.
Everyone on the forum is like this including myself.
Can you please provide more information than "Doesn't work"? Do you receive an error message? Is the output different than what you expected and if so, what is the output and what did you expect it to be? Can you screenshot the configuration?.
When I type /firstwarning
This appeared - This is your final warning for breaking the shoutbox rules. If you continue to repeatedly break the rules this will result in you being banned from the shoutbox and possibly the forum.
When I type /firstwarning members name ie. (/firstwarning Ton)
Nothing appears
When I typed /firstwarning Ton I expected it to let that member know hes hard a warning. Instead no ones knows who the warning is for.
I wanted members who have posted 3 times in one day to be able to use the shoutbox. Is there an option for that? Is the option you are talking about average posts per day?
When you visit the shoutbox, do you see a yellow light next to the Shout button? It's grey if you've not shouted or performed any administrative actions, and green if you're flagged as active.
Nothing appears
Create this custom command:
Command Input: /firstwarning
Chat Output: /pm {1}; This is your final warning for breaking the shoutbox rules. If you continue to repeatedly break the rules this will result in you being banned from the shoutbox and possibly the forum.
Use Parameter: Tick this box
That will send a shoutbox PM to the user receiving the first warning.
No. Average posts per day of 3 means that a member would need to have posted 3 or more posts for every single day they have been registered on the forum. For instance, if someone has been registered for 30 days, they will need 90 or more posts to see the shoutbox. 60 days, 180 posts. 120 days, 360 posts. Etc.
Top of Every page = Fixed
Commands = Fixed
Thanks Fillip H.
Active users
Screenshot https://tmpdmp.com/i/cc1e0fdad0d81ce4/6d0cee1f3e436bad
When members are posting on the shoutbox their usernames do not show up nor does mines.
Posts per day
Screenshot - https://tmpdmp.com/fa076890a871372e/200da639fb97fcc3
I want users to post 3 times per day (within 24 hour period) to be able to use the shoutbox. When this is set to 3 even after 3 posts only admin can use the shoutbox.
Shoutbox to thread
Archive Thread Dump Forum - Set to a forum category but I have yet to see a thread/post.
Active users
Posts per day
That cannot be done, as per my previous post.
Shoutbox to thread
You need to manually generate the dumps by going to the Archive and ticking the boxes for the shouts you want to export, then click Create Conversation Thread.
Sorry for the delay on the on-site support, I've been massively busy this week :(
The Active Users issue was due to an incorrect setting in the Instance Management, the Timeout setting was set to /. I changed it to 0 and it now works as intended :)
Thanks Fillip H..
No problem with regards to the time it wasn't a major problem.
Keep up the good work.
