Question Friendly Internal links
markoroots
Hi Fillip,
I didn't remember what i have change but the internal links in the post aren't shown friendly but in the normal way.
What I can do to change this setting?
Thanks in advance.
Hi there,
There is no setting for this, it happens automatically.
Unfortunately, v1.3.7 is no longer supported. You would need to upgrade to the latest version of DBSEO (at the time of writing, v2.0.31) in order to receive bugfix support.
Hi Fillip it's not a bug.
I have moved some setting so I have done something wrong.
Before the links of the other threads of the forum, when posted inside the posts in the forum appeared with the title of the thread. Now is visualized not the title of the thread but the normal link.
Can you please tell me where I can found the setting that change this way to show the internal links?
I've been unable to find any setting that affects this, you'll need to upgrade to the latest version of DBSEO in order to receive bugfix support unfortunately. v1.3.7 is no longer supported for bugfixes.
Sorry I couldn't be of more help :(
Thanks Fillip, yes Dylan told me how to fix and I have done it. :)
So I think you can close the thread, also if I will reopen it one time I will have renewed the seo plugin. :)
Regards ;)
Hello markoroots,
As this is a duplicate report to one of your other threads that I posted in before this, I'll close this :)
