Question Forum rewrites inside directory gives 404
sGroupInt
I'm trying to set up my forum with dbSEO inside a folder "on".
The URL strecture would be absoluteauthority.com/on/forumtitle.html
When I try to use the forum URL Rewrite I get a 404 error.
I got the rewrite to work in the main directory, absoluteauthority.com
Is there more setup that is required for it to work from a folder?
Thanks for your assistance
Hi there,
Do you have an actual directory on your site called on? If so, that is the reason why this will not work. Please delete this directory to enable the rewrite to work.
Hello sGroupInt,
