Question Duplicate postbit info
djvj
My postbit is showing duplicate Thanks statistics and I can't for the life of me find where this info is being called twice.
I use postbit tabs, it shows once above the tabs (incorrect) and once in the tab (correct). If I enable the Manual Postbit Deployment setting, it removed it from the postbit tab, but not from above the tab. I've searched my postbit templates for "thank" and get no hits, so it's not being called in there.
Where else can I look for why this is happening?
Thanks Fillip H., but as I stated in the first post, setting that only removes it in the postbit tab, not above the tab. It's still being called elsewhere and could possibly be a bug.
In that case, make sure you go to Postbit Tabs and edit the relevant View to fit it under the grouping you need.
That was it! I don't know why, but somehow I had 2 entries in postbit tabs:
DragonByte Tech: Advanced Post Thanks / Like - Thanks Stats DragonByte Tech: Advanced Post Thanks / Like - Thanks Stats
DragonByte Tech: Advanced Post Thanks / Like (Lite Postbit Integration
One I had assigned, the other I did not as I did not notice the 2nd one. Thank you.
