Bug Double tabs
dknelson
I love this mod and will definitely buy the PRO version because my members want to create their own favorite smilies. I have a problem though. It works great in the full editor but in quick reply, it shows the created boxes twice. In the example I will show, I have only one box created named "Standard Smilies" but it shows it twice. If I create more boxes, it shows them all twice. Only in quick reply. It works properly in the advanced editor.
OK...I figured this out. It was caused by another mod that I had done. My members like a navbar at the bottom of the last post in a thread. I had added {vb:raw navbar} just below the second instance of next previous in the showthread template to add a copy of the top Navbar to the bottom. That is what was causing the issue.
I have removed that Navbar for now but I've tried putting it back in several places and wherever I put it seems to cause the above problem. This mod is more important but any idea where I had add the second Navbar that won't cause this problem with your mod?
I don't want another top navbar. This was a bottom navbar. Does that do it?
Well I got around this. I didn't find any way of adding a bottom navbar to the show thread and post listing pages but I did find a mod that simply adds buttons beside the "quick navigation" menu at the bottom of those pages. One button takes you back to the first post of the thread and the other takes you back to the listing of threads in the forum you were in. That is primarily what my members wanted and it doesn't interfere with this mod.
It would be nice to have a way to add the bottom navbar but everywhere I put it, it conflicts with the VBEditortabs mod.
So...I guess what I have it good enough.
Legacy vBEditorTabs
