Bug Copyright notice with Copyright Management
angus
Hey guys!
Not sure if this is a bug with the new Copyright Management or the Slider 1.06.
When the copyright is displayed in the footer it will not removed by the copyright management addon.
But the product is listed by it.
So there are 2 Copyright notices.
regards
Angus
That is a known issue, it is with the slider. If you have the new Copyright Management mod installed, just move the slider copyright back to the slider and it will not double up in the footer, or show up under the slider as long as the Copyright Management mod is active.
I will work with Ozzy on this, and I haven't used it at all, but I guess my question is: if the copyright in the slider is selected to below slider and copyright management enabled, then the copyright only shows up in the manager, then what is the issue? Perhaps I'm misunderstanding what Ozzy is saying above.
Either way, I will look into it.
Brad via Tapatalk
Basically yeah, if the copyright is below the slider, and the copyright management mod is enabled, it only shows up in the copyright management line.
But if you have previously selected the branding to display in the footer, and enable the copyright management mod it will show the copyright in the copyright management line and on a line of it's own.
So for now the simple solution it to select the branding to display under the slider if you have the copyright management mod enabled, and it will only show on the copyright management line.
Yes this is really a solution.
Thanks for this hint
Legacy vBSlider
