Legacy Contest Settings
GoodApples
Contest settings are set to
Public = Yes
Show Criteria = No
To improve the product I believe it would be best to not show the N/A settings. If there are excluded there is no need to show it to all usergroups.
I am about to start my first contest and testing. :) It would be better if this didn't display to all usergroups.
That'd be challenging due to the fact that other contests could have data there. Hiding table cell rows is a bit trickier than replacing N/A with data.
We'll take it into consideration, though :)
If there are multiple contests active...is all the info displayed in the same area?
I would have thought it was just for the one contest being viewed.
I was thinking each active contest had it's own page for the data.
Note: When referring to the N/A = I was referring to the entire area in the oval circle. ;)
Thanks for taking it into consideration. :)
Legacy vBActivity & Awards
