Bug Admin CP Logout issue
Could you elaborate on why you believe this is an issue with DragonByte Optimise? We have had no reports of this happening anywhere, and DB Optimise does not cache user accounts in any way, shape or form.
Its happened after Installed DragonByte Tech: Optimise (Pro) 3.0.0b1 but We are using Varnish Cache on the server level. Does its Varnish Cache issue?
Since Varnish is designed to cache the full page then it's very likely Varnish is the reason :)
Varnish is stopped but I have still this issue, Now this work after doing Flush Cache but this issue happened before 5 day then i do Flush Cache and its worked for 3 day then its happened now.
I am not able to replicate this issue @ your site just now. Logout performs exactly as expected.
Can you please provide me the step-by-step instructions for how to replicate this issue?
Our one admin said that, Today the condition is very worst. Every time it shows a message "Log In" to continue.
Disabled DB Optimise then we are not getting this issue no more.
I've changed your configuration to use FileCache instead of Memcache, in case there's a problem there. Without a way of reproducing this issue 100% of the time, there's a limit to what I can do :(
Hello Nirjonadda,
Legacy DragonByte Optimise
XenForo 1.5.3+
