Question vbseo and arcade
doctorsexy
Hi... what do i need to add to the arcades .htaccess file to get vbseo and the arcade to work on my server..thanks
What does "working" mean, what issues are you experiencing? DBT has the arcade and vbseo running and the are working well. I dunno if anything was added to the .htaccess to solve any issues between the two.
work
Physical or mental effort or activity directed toward the production or accomplishment of something.
So to put it another way ...... what needs to be added to make the arcade scores submit with the vbseo .htaccess file.....:D
I fixed the .htaccess code to work with vbseo a couple versions ago. If you installed vbarcade and it isn't working, send me the contents of your .htaccess file and I will let you know if there are any changes that need to be made or if there is a problem we need to investigate.
Question Arcade Menu
Legacy vBArcade
