Bug Urls with latin charactere are redirects
Portekoi
We are using VBulletin 3.8.11
I've made the update of the last version of DB Seo and we have migrate our server because of a huge traffic.
Since that, I have a problem with Urls where there is a latin charactere replaced by the equivalent.
Example :
http://forum-seduction.artdeseduire.com/presentations/ ==> (normally, présentations replace by presentations)
redirect to : http://forum-seduction.artdeseduire.com/
But, if I go on a post, it's working :
http://forum-seduction.artdeseduire.com/presentations/90790-bonjour-toutes-et-tous.html
I've enable UTF-8 parameters in the admin cp but without success.
Thanks,
Damien
That sounds like a htaccess conflict. Furthermore, you should check to make sure your forum names do not match any subfolders in your forum folder.
The best way to avoid this is to use forum IDs as part of the forum URL, it is not recommended to use the format you’re currently using. Continuing to use that format will make it impossible to redirect old content should you ever upgrade to a more modern forum software such as XF2.
Works fine in Safari for Mac. Can you please try clearing your cache in Firefox?
Hello @Portekoi,
