Bug Thread Pagination Issue
Holden
Our htaccess rules
# Comment the following line (add '#' at the beginning)
# to disable mod_rewrite functions.
# Please note: you still need to disable the hack in
# the vBSEO control panel to stop url rewrites.
RewriteEngine On
RewriteCond %{REMOTE_ADDR} !81.96.96.105
RewriteCond %{DOCUMENT_ROOT}/maintenance.html -f
RewriteCond %{DOCUMENT_ROOT}/maintenance.enable -f
RewriteCond %{DOCUMENT_ROOT}/maintenance.png -f
RewriteCond %{SCRIPT_FILENAME} !maintenance.html
RewriteRule ^.*$ /maintenance.html [R=503,L]
ErrorDocument 503 /maintenance.html
Header Set Cache-Control "max-age=0, no-store"
# Some servers require the Rewritebase directive to be
# enabled (remove '#' at the beginning to activate)
# Please note: when enabled, you must include the path
# to your root vB folder (i.e. RewriteBase /forums/)
#RewriteBase /
#RewriteCond %{HTTP_HOST} !^www\.p0wersurge\.com
#RewriteRule (.*) http://www.p0wersurge.com/forums/$1 [L,R=301]
#RewriteRule ^((urllist|sitemap_).*\.(xml|txt)(\.gz)?)$ vbseo_sitemap/vbseo_getsitemap.php?sitemap=$1 [L]
#RewriteCond %{REQUEST_URI} !(admincp/|modcp/|cron|vbseo_sitemap|api\.php)
#RewriteRule ^((archive/)?(.*\.php(/.*)?))$ vbseo.php [L,QSA]
#RewriteCond %{REQUEST_FILENAME} !-f
#RewriteCond %{REQUEST_FILENAME} !-d
#RewriteCond %{REQUEST_FILENAME} !/(admincp|modcp|clientscript|cpstyles|images)/
#RewriteRule ^(.+)$ vbseo.php [L,QSA]
#RewriteBase /
Options -MultiViews
It's causing us not to go to the second page on threads but when disabled it lets us view the second page.
Please provide more information than "doesn't work". What happens instead? 404 error, taken to another page entirely, etc?
It only loads the first page of posts on a thread and when selecting second page on a thread doesn't allow us to go to the second page on a thread just stays on the first page.
