Question tagging usernames with spaces
SWR
We're running Advanced User Tagging v 3.0.8 Pro.
I never noticed until a member brought it up that you can't tag a user with a space in their username.
ie: You can @SoftWareRevue
You cannot @ SoftWare Revue
Is there a work-around? Our members prefer not to use the ";" to single the end of the username. But if that's the only way, that's the only way. I just want to make sure that using only @ is not possible before I tell members it's not possible.
Thanks for any insight you can bring.
Regards,
Dennis Johnson
aka SoftWareRevue
I'm unable to replicate this issue. Please make sure the usernames are spelled correctly when attempting to use the Mentions feature.
Legacy Advanced User Tagging
