Slider question
vetsfast
Just curious how many different style do you have for this?
I am looking for one that is compatible with VBA (which you have) and has small arrows that allows you to browse through the slides.
Thanks
Slide navigation currently isn't available, but it is in the next version, which is currently under development.
As far as styles go, I'm not sure I fully understand the question. I will say that it is fully customizable via Stylevars though. Hope that helps.
Brad via Tapatalk
well i think that answer might suffice.
Looking forward to the next version, i may just in fact purchase it.
Thanks
To answer the question about styling, you won't have to make any changes, out of the box the slider will match perfectly with your style.
If you want to make adjustments you should be able to do easily.
