Feature Request Sidebar
Website
http://footballchatter.com
Forum version
vBulletin 4.1.x
Belazor
Staff member
Owner
Developer
This mod integrates with all the ad locations you can define in vBulletin by default, nowhere else.
#5
Do you foresee it happening anytime soon?
It would be nice to use only one companies software enhancements on the forum. That way you can be pretty confident thy will work with each other.
Belazor
Staff member
Owner
Developer
You could actually do this yourself - if you open /includes/xml/ and observe the two ad_location_<>.xml files, you'll see how you can add custom ad locations. Add a new ad_location_<>.xml file and use the template from those two files.
You might need to do a bit of experimentation to find the correct X/Y/width/height variables to make it look good on the "Add New Ad" page.
Once this is done, you can go to ForumAds - Maintenance and click Repair Integration.
The last step would be to add the ad_location variable to the sidebar block you wish to include.
We could also do this for you as a custom work project, you can read more about that and request a quote here: Custom Work - DragonByte® Technologies | vBulletin Mods & Addons
DragonByte Forum Ads [Hostboard]
