Bug Several errors after install and Shop tab not appearing
Dang, I'll just have to trust that members won't try to 'cheat' and constantly post and delete :P
Just one more question, is there any way for admits to modify a user's currency on the front end?
Anywho, thank you so much for the support, really appreciate it :D
Via DragonByte Credits, set up an Adjust event, and set Affected User to Receiving User.
Only usergroups with the appropriate permission (XF global permissions) can access Adjust events.
Then, click on any credits display anywhere on your site to open the overlay that lets you perform adjustments.
Hm, that's weird, the Adjust isn't working. I clicked the username, I click the currency, went to adjust, and confirmed, but the currency doesn't increase
Also, It does look like the conversation notification for the shop or credits are working =/ (just not my lucky day today haha)
Do I have to put the User ID in here instead of the name?
Can you please double-check that you didn't accidentally select any usergroups when adding the Adjust event? The usergroup selector in the event configuration only affects what user groups can be affected by this event, so if you selected your staff groups there, it means only staff groups can have their currencies adjusted.
Ah, for some reason I thought you meant the user groups are only the ones which can use it
Any idea about the purchase notifications?
Just did some further testing, and it seems that the Alert functions are non-functioning on my side =/
Maybe I missed something?
DM me if you need access
Then I will need all the credentials restored in order to look into this as it is not an issue I am able to replicate.
I think when you fixed some of the things from earlier, it's cause the XenWord plugin to act weirdly. I can update to a newer version of it and it doesn't post the article to the forum =/
If you updated to a newer version, it's likely you have undone my fix to it as the author did not respond saying they would include my fix in a new version of the product.
You can follow the discussion, and apply the fix manually yourself by following the steps outlined here: XenWord [Paid] | Page 44 | XenForo Community
I haven't updated it recently (tried to under a new directory but it wouldn't allow me to)
Were you able to check about the notifications not working though? I reactivated your permissions
I've had a brief look at your site and I forgot that the "Conversation" and "Email" alert types are not yet implemented. I have switched it back to the "Alert" type, which should generate a XenForo Alert notification when an event occurs.
Sorry for the confusion :(
Thats okay, but what about for the purchasing of products? I tried a test purchase, but did not get a notification that the item was purchased. This is critical as there will be items which will require my instant attention when purchased
Go to the AdminCP and edit each of your items, click the Per-Shop Inventory Configuration tab and fill out the Purchase Notifications field as per the on-screen instructions :)
Question Shop Icons
DragonByte Shop
5.00 star(s) 3 ratings
