Question Problem with the URLs
mpursell
Product it's the latest version installed:
I haven't found a proper way to get these two rewrite rules work on a same .htaccess
There was a migration on this site that made it work from www.site.com to www.site.com/forums/
And to make that migration work fine, there're two scripts, one does a redirection from the old URLs within a synced new URL ID, and the second one are rules from a SEO suite on the software.
So, I'm stuck making both work fine, can you help me?
#Rule 1 Start
# If this one is enabled, the second one doesn't work and viceversa
RewriteEngine On
RewriteCond %{QUERY_STRING} board=([0-9]+)
RewriteRule index\.php vbseo301.php?action=forum&oldid=%1 [L]
RewriteCond %{QUERY_STRING} ^board=([0-9]+)\.([0-9]+)
RewriteCond %{QUERY_STRING} topic=([0-9]+)
RewriteCond %{QUERY_STRING} ^topic=(.*)\.([0-9]+)$
RewriteRule index\.php vbseo301.php?action=thread&oldid=%1 [L]
RewriteCond %{QUERY_STRING} ^topic=([0-9]+)
RewriteCond %{QUERY_STRING} ^topic=(.*)\.msg([0-9]+)$
RewriteRule index\.php vbseo301.php?action=post&oldid=%1 [L]
RewriteCond %{QUERY_STRING} action=profile;u=([0-9]+)
RewriteRule index\.php vbseo301.php?action=user&oldid=%1 [L]
#Rule 1 Ends
#Rule 2 Start
# Options -MultiViews
RewriteCond %{REQUEST_URI} !(admincp/|dbseocp/|modcp/|cron|mobiquo|forumrunner|api\.php|index\.php|reviewpost/|classifieds/|photopost/)
RewriteCond %{REQUEST_URI} !/(index\.php)/
RewriteCond %{REQUEST_FILENAME} !/(admincp|dbseocp|modcp|clientscript|cpstyles|images|reviewpost|index\.php|classifieds|photopost)/
#Rule 2 Ends
So I'm to understand you've imported to vB from another software, and you're needing to make old URLs redirect to their vB equivalents?
I would recommend putting the "Rule 1" sets in a .htaccess file in the parent folder, and Rule 2 sets in a separate file in the /forums/ folder.
