Question Problem with Google Authenticator
highlander
I'm trying to run SEO reports and it is asking me for my Authentication Code from Google. I do have two factor authentication set up on my Google account. Normally the way this works when I access from a different device/location is that I receive a text message with the code or i receive it on the authenticator app. How does this work with DragonByte SEO? It doesn't seem to generate a code that is sent to my phone or the authenticator app. Is there something I need to do to trigger it to generate the code?
This is the error I keep getting:
Error fetching OAuth2 access token, message: 'invalid_grant' on line 119 in /home/typology/public_html/forums/dbtech/dbseo/includes/3rdparty/Google/Auth/OAuth2.php (code: 400)
Make sure your popup block is off as a window will popup and you need to login. It will then take you to the screen with the ID
11K
