Hi: I have a forum that currently runs VB 3.8.6 and Photopost version 5.2. yes very old The forum is going to be upgraded to VB 4.2. My understanding is that your gallery software does not work with VB 3.x.
This is a 2fold question;
is there an exporter that can be used to map from 3.x to 4.x?
If there a way to export from photopost 5.2 do the upgrade install DB Gallery then import the mappings? Lots hinges on this, so Trying to find the best answer. if it helps the images are located on the server (and there are lots of them)
