Bug Permissions not being saved
stig
I have 2 instances set up.
In all instances, when you hit "Save" on the top set of options (Above the permissions area) it clears out ALL permissions, and you have to re-edit them again.
Edit : Sorry - I didn't even KNOW I was running Suhosin.. I'll try your hack for that and report back..
Please note that with all Suhosin installations, the Options, Permissions and BBCode Permissions are 3 separate forms and must be submitted separately, even with the hack added.
Yep, I understand the three separate blocks..
The problem I'm seeing is that when you save the first block, it clears out all selections on the second and third blocks..
Which is really annoying if you have lots of separate groups like I do :(
No, it's still doing it for me on the second instance..
I'm not game to touch my first instance, it takes forever to set back up again :(
