DemoniK Customer Jan 9, 2016 #1 I installed beta of the pro and lite versions of the plugin. Shoutbox works - but there is no instance management in the admin console. All I see under Applications is ---- DragonByte Tech: Shout ~shout.placeholder~ ----
Fillip H. Staff member Owner Developer Customer Jan 10, 2016 #2 Hi there, Could you please try disabling all other modifications? You may have a mod conflict of some kind, as I can't replicate this on any of my test forums.
DemoniK Customer Jan 11, 2016 #3 I had started doing that.. takes some time.. But I narrowed it down to 1 plugin [TH] Install and Upgrade | XenForo Community
Fillip H. Staff member Owner Developer Customer Jan 11, 2016 #4 In that case, you will need to contact the author of that product for assistance. Sorry I couldn't be of more help
DemoniK Customer Jan 11, 2016 #5 somehow I guessed that would be your response.. Completely understand though.. and of course the other guys will just point the finger at you. Not to worry - in this instance I don't need to run their plugin all the time, and when I do, I think I can put up with this bug until I disable
