Question Installed responsive style, can't get thanks/like to work on it.
ae1360
Just a simple question on if this is going to be a problem. I know this doesn't work on mobile but I figured it might work on a responsive style. It loads and everything but the buttons don't react and it isn't changing the post colors on this style.
http://i.imgur.com/FZEKcpu.png
That is the error you see in the console. Starts on line 3 on Chrome, IE says 2 and 3 of thanks.js
That means the style is using a very very old version of jQuery. I would strongly recommend editing it to use a newer version of jQuery.
Phew. I saw how fast you replied and all I could think of was 'that cannot be good'.
Hrmm...so where would it be that I could change this out? Just in the original XML? Strange also it is using an old version of jquery given that the style was just made a few months ago.
I cannot see the style on your site as a guest I don't think, at least no copies of jQuery are included, but try searching for jquery in the templates.
Fixed it. I dismissed this as being the cause early on because I put a new jquery in the headerinclude and it didn't do anything. Needed to be in footer.
Hello ae1360,
