Question How to hide info in postbit?
dimas
Hello. How can I hide the Likes given info from the guest, if I'am right understand, I need to place this code
{vb:raw thanks_postbit} within the conditionals in postbit legacy template. But can you please let me know, what exact conditionals and where exactly in code I need to place it?
It's turned on, the buttons are hidden but I want to remove the Likes given, Likes received from the member info column
I mean this
check it
settings
You can edit each button and control whether the Given and Received stats should be displayed.
I understand that, but what I really want to hide from the guests is this line
attachment.php
You have already done so via the settings, I visited your forum as a guest and I did not see those statistics.
That is due it's inactive at the moment. I just want to know where in code, I can place it manually?
Please check this. It's not logged in
Before you did not discover likes- it was turned to the manual mode, which is deactivate it at all. You can now see that it's visible to all unregistered.
And result with keywords by google
Ah, I see - the setting is actually only designed to control the actual "bar" (with the list of who clicked thanks). I have made a change to the postbit file to also hide the statistics.
Still no reply.
Bumping your thread will not increase the priority with which I am able to respond to your thread, if multiple other people have issues that need to be addressed first.
Sadly it is not possible for me to answer everyone's support query instantly, please have patience.
Thank you for your understanding.
