Bug Front Controller Issue
hakkuo23
So I have a callback for various add-ons and when the event listener for xenforo_model_user is enabled, it causes this error:
Fatal error: Cannot declare class XFCP_(goes down the line)
If I go to DBTech_Shop_Application_Core and comment out the exception handler in the constructor, the error goes away and the entire website functions as normal.
It looks like it's declaring a brand new front controller there which is causing serious issues with other add-ons. I'm quite sure if you replicate this with the user upgrades it will occur for you.
I have also disabled every add-on and when enabling this one the error comes back.
Thanks!
Historically, this will only happen if you have another thing on your site initialising XF in a non-standard way, such as XenWord. Is this the case for you as well?
No it's the user upgrades paypal callback, another credits addon callback and a custom callback I wrote.
Very strange that no-one else has reported this issue while still running both modifications.
Can you try disabling all other modifications, leaving only DB Shop and Credits enabled, then replicate the steps that your users take to receive the issue, and see if it still occurs?
I already did that and it was DBShop causing the issue. Basically as soon as I hit any model using XenForo_Model_User the error happens. Disabling that event listener for that class stops the issue.
Sorry, I mean leaving DB Shop and DB Credits enabled, disabling all other modifications. As this is not an issue I can replicate anywhere, it's likely another modification is causing DB Shop to create those errors and I need to know which modification it is.
I'm not using DB credits but AD credits. Keeping that enabled and enabling DB shop causes the error.
Hello hakkuo23,
DragonByte Shop
5.00 star(s) 3 ratings
