cakearmymax
Hi,
I'm currently using PrometheusIPN with the attached php scripts to allow my website to initiate a remote connection into my gameserver and give the users with an active subscription their package.
Here's how it works:
Users sign in with steam. It converts their steam to the 64/hex value and the sends that along with some other parameters to the server which handles the rest. There is a cron job running on "minutecron" which executes everything every 60 seconds.
What do you think something like this would cost to integrate? Thanks!
Edit: Not sure if it worked, but I did attach the 3 php files it uses.
Upvote
