Bug Dynamic Meta Tags not working properly in threads and forums
Nova99
Hi
I have just installed the latest DBSeo mod on my vbulletin 3.8.7 (imported VBSEO settings) and everything seems to be working fine, except the Dynamic Meta Tags in forums and threads.
It doesn't change the keywords or the description in any pages, the default is just displayed everywhere.
The only place it seems to work is in the member profiles...
Any idea what may be causing it?
I've tried to disable and enable all of the options in the Dynamic Meta Tags Settings, but nothing happens.
Thanks
Are you having this issue with the custom descriptions via the Edit Thread menu, or are you saying the default values from "General Settings" in the vBulletin Options (not added by DBSEO, but stock vBulletin) is being used?
I'm unable to replicate either of these issues, mind, but I want to be clear on what exactly the problem is before proceeding :)
Both actually. :)
It's only using the default values from vbulletin, nothing happens with the description and keywords at all, even if I manually edit the thread and adds a custom description and keywords for that thread.
But when I edit the thread, under Meta Description and kewords there are keywords and a description that I guess are from DBSeo but it isn't displayed in the thread meta description/keyword, so keywords/description from DBSeo isn't replaced/used at all on the generated thread it seems.
Hope that made some sense.. :p
My template has been modified quite a lot, so it's possible that it may be missing a hook or some template code used by DBSeo to replace keywords and descriptions??
Tested on the default skin style now, and no luck there either....
It's strange that it's working fine in the member profiles, but not on the other pages.
Was able to add it manually by using $threadinfo[dbtech_dbseo_description] in the meta descriptions for threads and forums in headinclude, so it's sort of working now.. :)
Alright, if anyone else reports this problem and their assistance leads to a solution, you'll also receive the solution via an update :)
11K
